SG5 Forester Surge
GSubXR
I am hoping someone here can help me out, I have an SG5 02 forester XT turbo manual that is having a bit of a surging issue. It doesnt happen all the time, and it doesnt matter whether it is on boost or not, but at low to early rpm, when i give it slight acceleration, the car starts surging. It will start running normally once the revs are up. I was wondering if this is a known fault or has anyone struck this issue before?
I have an 02 forester xt aswell, I have had problems with mine for the last year or so with it occasionally surging and not boosting properly. I had no Cel come on so was a bit of a guessing game. The car did drive a bit better when I cleaned the maf so I started there. I replaced the maf a couple of weeks ago and happy to say it has fixed the problem it is driving like new again. Try cleaning the maf and if it helps it might be worth replacing cheers
  • 3 months later...
Ok so today i had what i guess you could call a breakthough in my fuel surge issue. i pulled out from an intersection, it got up on boost, coughed and spluttered a bit, then as i slowed down for a roundabout, i put my foot on the clutch, the revs took a nose dive to zero, lost all power (obviously) then creeped around the corner out of traffics way, and my engine light came on! so i thought i finally have a fault code to point me in the right direction, so got my diagnostic equipment and plugged in, it came back with stored code p0230 - fuel pump control. its still in the history but the light itself has not returned, even after i got it running, it will idle for a while but wont rev at all. so my new question is, do these things have a separate module for the fuel pump, or is the controller part of the fuel pump itself??
P0230 Fuel Pump Primary Circuit Malfunction
OBD-II Trouble Code Technical Description
Fuel Pump Primary (Control) Circuit Malfunction
What does that mean?
The fuel pump is activated by a PCM-controlled relay. Just as the name implies, a "relay" permits the transmittal of higher amperage current to the fuel pump without that current having to travel through the PCM (Powertrain Control Module). For obvious reasons it\'s better to not have higher amperage current anywhere near the PCM. Higher amperage current creates more heat but also in the event of a failure, can cause a PCM failure. This principal applies to any relay. The higher amperages are kept under the hood, away from sensitive areas
The relay contains basically two sides. The "control" side which is basically a coil and the "switch" side which is a set of electrical contacts. The control side (or coil side) is the low amp side. It\'s fed a switched ignition feed (12 volts with key on)and a ground. The ground circuit is activated by the PCM driver when appropriate. When the PCM fuel pump driver activates the relay coil, the coil acts as an electromagnet that pulls the electrical contacts closed which completes the fuel pump circuit. This closed switch allows voltage to flow on the fuel pump activation circuit, activating the pump. Whenever the key is turned on, the PCM grounds the fuel pump circuit for a few seconds, activating the fuel pump and pressurizing the system. The fuel pump won\'t be activated again until the PCM sees an RPM signal.
The driver in the PCM is monitored for faults. When activated the driver or ground circuit voltage should be low. When deactivated the driver/ground potential voltage should be high or near battery voltage. If the PCM sees a voltage other than what is expected, P0230 may be set.
Symptoms
Symptoms of a P0230 DTC may include:
MIL (malfunction indicator lamp) illumination
No start condition
No fuel pump operation
Fuel pump runs all the time with ignition on
Causes
Potential causes of a P0230 code include:
Short to ground on control circuit
Fuel pump control circuit open
Short to battery voltage on control circuit
Harness chafing causing one of above conditions
Bad relay
Bad PCM
Possible Solutions
Command the fuel pump on and off by using a scan tool or simply turning the ignition key on and off without starting the engine. If the fuel pump activates and deactivates, then start the vehicle and measure the current on the control (ground) circuit for a couple of minutes. It should be less than an amp and stay less than an amp.
If it doesn\'t then replacing the relay is a good idea at this point. If the fuel pump won\'t activate and deactivate, then remove the relay and visually check for discoloration due to heat or loose terminals. If okay, install a test light between the control circuit ignition feed and ground driver terminals (If you\'re not sure, don\'t attempt).
The test light should illuminate when the key is on or the fuel pump is commanded on. If it doesn\'t, then make sure there is voltage on one side of the coil (switched ignition feed). If voltage is present repair the open or short on the control ground circuit.
Article written by Dale Toalston
http://www.obd-codes.com/p0230
Yes they are. im gonna take it to wingers so i know exactly what the issue is so i can fix it myself, just get them to finish the diagnostics i think. although even if its not the pump and just the controller, im still inclined to do the pump anyway. fit a walbro or something similar... ideas?
