Error Codes P1308 and P0340
Minaj
Recently i have came across two problem codes are P1308 and P0340 i replaced my camshaft position sensor and it still chuck the ecl during high revs. Another code that came along did some research about it but nothing has came up is i got a error code P1308 ecl comes on and off and stays on. I have also relised that it has been idling very weird sounds like lumpy cams anyone have any ideas or any information what i could do ?? its a Wrx sti 2001.
P0340
Camshaft Position Sensor Circuit Malfunction
P1308 OCV Solenoid Valve Signal 2 Circuit Malfunction (Open)
Cheers Minhaaj
I dont tune my friend does it for me using romraider. I got rid of the first code, i removed all the camshaft position sensors in the car theres like 4 cleaned the wiring and cleaned the sensors to there was oil both in plugs and in the sensor. After cleaning i deleted the codes and hasnt poped up yet. Still got the 1308 to figure :(
pull out green plug from alternator and check if your engine idles properly or not and if the cam code goes away. we have a lot of cases where the alternator plays up and give wrong current to cam sensor, even though the alternator is charging properly.
as for code p1308, i have the complete repair procedure for it. if you live in auckland than you can come and i will check it for you.
 Minaj said:
Wire was split inside the loom where it connects to the plugs where all the other wires meet up, was a mission to find but got there. Will upload if when i have time.
is that the big plug by the boost solenoid?
yea man load a pic...
good find!
