Function vs form - happy camber medium
They seem to be the only ones doing ## 3/4" fitments lol. I like the 962 in about 9" wide 8.5 looks a little funny. Would need wider tires though as have 215/35 and need a 40 when you start stretching stuff to far.
With a v7- you are so spoiled for wheel choice. Ive got some awesome GD/wheel porn on file.
Spaced the rear wheel 6mm last night to have a look. Looks better but really cant tell till i get the struts in to see where it sits whens its at a realistic height. If it looks good without spacers I wont bother as be one less illegal item. :o Got camber bolts front and rear but may go to camber bolts in lower rear also depends how much camber i get out of it/what Im happy with.
I considered those wheels but was going widebody too, custom made to fit the rims on gc8, a Gdb will have more chance of fitting but you will have to at least roll arches. Is 5 degrees the current limit on camber?
unsure what it is thinking factory +1 or 2 degrees maybe someone knows have seen a gdb fit them with 6 degrees on the rear and 4 upfront
