Mysterious coolant leak 1996 WRX
Hey fellas I\'ve signed up to this forum for some help.
I have a 1996 Subaru WRX STI RA Version III that has a coolant leak. There is a noticeble puddle under the car after a drive.
The problem is I cannot find the source of the leak. When looking under the car there is coolant dripping from rear of the engine. It looks like its coming out of the steering rack near the jack plate (which I know isn\'t the case). I\'ve been under the car with it on axle stands and had a look but there too many things in the way to see anything.
I\'ve had a look around the throttle body and the heater hoses that go into the firewall and there are no leaks there. Couldn\'t trace the hoses back into the engine.
I recently replaced the thermostat and coolant so the coolant because I noticed that the bottom hose stayed cold. The coolant that is leaking looks new and not mixed with oil, It\'s still the same colour as I put in. Which is why I don\'t think its the head gasket.
From the research I\'ve done about this I\'ve been taken to Subaru Outback forums and most of them say that it is a external head gasket leak. I hope this isn\'t the case.
Does anyone have experience with this sort of leak?
If it helps the car has done 175000km and is still on the original motor.
Thank you very much,
Car\'s been parked up for a few days now and I haven\'t noticed any more coolant leaking. When I get the chance I\'ll take a look at the overflow and under the manifold although I didn\'t see anything last time.
Cheers for the ideas guys.
Yeah most likely turbo coolant hose will have a small split, will only leak under high pressure when driving, and won\'t be obvious when idling, Won\'t be external gasket leaks, That only applies to the later EJ251 SOHC motors.
Big thank you to subirex for having a look at this tonight. Managed to track down two leaks. One was from the turbo coolant hardline from rubbing against the engine and the other was the hose that goes into the header tank.
sweet!
