What is difference between???
scottharvey
Guest hate-evoz
Never had much to do with a forry before but kiwi fozze or the like will know
all I know is that an STI version of a forester may have a VF something turbo, maybe better injectors, better suspension etc stuff like that where as your standard forester will have a TD04,turbo grey injectors and so fourth but I don\'t know never researched or read anything about them
st/b were early SF5\'s? there was no STI version
STI Fozzys are only late model
(I DONT REALLY KNOW WHAT VERSION YOU ARE ASKING ABOUT PLEASE USE MODLE CODES)
Also I don\'t know if what i say is even correct because I only own a Legacy
There were a VERY limited run of sf5c and sf5d revision foresters (face lift model) available, with 4pots and no dccd, same engine as an sti impreza. Version 7 on, the sti was a 2.5 single scroll (japan) until first facelift on SG chassis, which became available as twin scroll (again, japan) same turbo as the impreza iirc. No dccd, but they got the 6 speed and brembos
 JoKer said:
is fun dragging info out of you guys :P this should make the FAQ now with those images :P
Best method is just say something wildly inaccurate - peeps can\'t help but correct :D
Then you end up with WAY COOL brochures being posted up which is mucho handy
