Issues
Maverick14
Howdy all,
I\'ve got an issue that I wouldn\'t mind your expert theories on.
I\'ve got a \'04 SG5 turbo cross sport that has developed some serious hesitation and surging when coming on boost and times where it feels as though there is not boost at all.
It\'s not throwing any fault codes, nor is it blowing any smoke. I\'ve had my brother in law (mechanic) look at it and his opinion was one or all of AFM, worn plugs or an issue with the coils. I\'ve only owned the car for 6 weeks and it\'ll be going back to yard for investigation, I\'m just cautious of them giving me the run around.
The car has done 120kms so it\'s at the stage where things are going to begin wearing out.
I\'m hoping for an easy (and cheap) fix.
Any thoughts?
Scott.
on the right hand side of the engine bay there is a grey plug that comes from the inlet. pull it out and see if it is filled with oil. if it is than change the inlet loom and both rear cam sensors. its a common faults on these models, where the rear cam sensors leak internally and pushes the oil inside the wiring loom causing heaps of problem.
