DIY - Battery Relocation
nt_a_foz
i wouldn't recommend using the CB as a master switch to often and dont do it under large loading, like if the starter motor is going or car is running with everything turned on, especially if you payed alot for it, as it can wear them out very quickly (the contacts burn, and they stop working correctly, or can weld together and wont open at all), unless its an emergency :)
-smurff
  • 3 months later...
  • 3 months later...
12mm2 cable is a tad on the small side to be safe, your ecu will be seeing huge voltage drops on cranking but not ahuge deal unless your battery voltage gets down, to run to your boot say 6m cable all up ( 5 positive 1 negative ) to keep the voltage drop under 15% at 230A 12V you need at least 35mm2 cable. Before i understood this ( im a marine mechanic and thus wire alot of boats ) i couldnt work out why the link in my celica kept turning on and off on cranking unless battery was realy full or was being jumped ( 16mm2 ). it can cause all sorts of problems large voltage fluctuations. including huge over voltages once the engine dose start because the alternator wacks out a huge surge. :) just a note for any one looking to do this. - ps a cheep place to buy 32mm cable may be your local marine sales shop as thats the primary cable we use .. its worth a shot
  • 2 years later...
