Turbo water feed no longer required
boon
I\'ve fitted an oil-only cooled turbo.
At the moment I have a hose running directly from the old turbo water feed to the tank up the top, but it\'s not very tidy.
Can I remove the fitting and Banjo and just block the sucker off or does it need to flow through there to avoid a nasty airlock happening somewhere down that way?
 boon said:
The oil feed banjo is M12x1.25. And yeah it\'ll be bigger. But I shall indeed block it off.
EDIT: With regards oil temps, mmm, will have to do a bit of logging on ze Link and see what happens.
daily driving would be fine, its the \'beating it\' sessions that you need to watch for sudden spikes or unrecoverable upward temp trends.
 funkytown']
This thing will probably never see more than a spirited drive out to Makara Beach or a quick blast past those fine folk who floor it at passing lanes.
Project Pigeonshit is for when I want to cane it like a red-headed stepchild.
