Tial Q BoV behaviour
boon
I\'m now running a Tial Q BoV off my TMIC.
I think it has the 11psi spring in it.
It\'s closed at idle and opens with just a little bit of boost which is all good, but if I have the car in neutral and give it a good rev the valve opens about half way.
I assume I\'m just increasing the vac as theres no load on so it doesn\'t make any boost... but do I need a stiffer spring in there? As it is I figure it\'s going to open under heavy engine breaking.
 Rosssub said:
My HKS Seq goes off %100 with a rev in neutral?
Sorry, to clarify... if I open the bonnet and rev it at the throttle body, watching the valve, I can see the valveopening while I\'m holding the revs, not when I close the throttle.
 lachlan said:
it wont open under engine braking .
it opens when you rev it coz the turbo is trying to build boost
if it doesnt sit open at idle then it wont open under engine braking
So I must be getting a solid 8psi or so of pressure differential across my throttle body then, with the throttle at like 30% opening?
I can\'t really decide if that makes sense or not. Does that mean that at partial boost the valve will open? I\'m confused.
 boon']
It\'ll be the "in neutral/no load thing" like you said wouldn\'t it? Holding the throttle open with no load/no boost the vac is enough to hold it open (like an NA). With no instant pressure change (load or deceleration) after throttle opening for the BOV to respond to.
Edit: Which could also mean that your BOV is opening slightly under initial throttle opening (vac+/-??), then closing when boost comes on. Have you got a straight Vac hose from mani to BOV? Maybe restricting it slightly might help (pill or filter, smaller hose)?
 Rosssub']
This is basically what I\'m concerned about - I\'m not worried about unmetered air because it\'s running a Link but it\'s the fact that the BoV doesn\'t exactly have a filter or anything that worries me just a little.
Yes, straight feed, using the factory hose. I don\'t want to restrict it as this will cause it to open slower and with the way it\'s built I\'m quietly hoping it will build boost quite quickly.
