wont run right
gts2wag
Hey umm bit wierd but other day my battery went flat so i replaced it had to play with the terminals a lil before it would start now its running real rough anyone have any ideas? Its just a standard 95 gt legacy manual if that matters? Any help would be greatly apprieciated, thanks
Make sure the Loom plugs near/behind the battery are still tight. Maybe something got knocked loose when the new battery went in? How\'s your Alternator, charging ok?
If it\'s starting fine, just idling rough. It may be a new vac leak/split hose etc, not caused by the battery fault.
Cross your fingers.
Clean and check all electrical connections.
Check for vac leaks.
Try an ECU reset.
Check for fault codes.
No worries, welcome to Clubsub :D
The Reset Procedure and CEL info is in here (Legacy FAQ\'s):
http://www.clubsub.org.nz/forum/index.php/topic,58.0.html
But if your CEL (Check Engine Light) hasn\'t come on, it wont be a fault code (sensor) issue.
More likely a Vac leak, maybe buggered/dirty AFM?
Or an Ignition fault, Spark Plug Lead loose/Spark Plug Dirty etc. While it\'s idling, pull the Leads off at the Plug one at a time (with insulated hands) to see if the idle changes. If 3 leads/plugs make it worse, but 1 does nothing that one is the dodgy one. Pull that plug out and check it over.
 gts2wag said:
Sweet thanks man will check it when i get back to the car. How could i tell if the coi is stuffed? Or are they pretty good?
the early coils like what you have arnt the best.
basically if you unplug a coil and it makes no difference it sould be either the coil or maby the plug. could be further back but more likely the coil
 rex-leggy']
Exactly what i was thinking, Also if it is air leak get a can of supercheap degreaser and spray around gasket hoses etc while the car is running, if there is a leak the rpm will increase, doesn\'t take long to find a leak if there is one doing it this way ;)
If it\'s just one cylinder not firing it won\'t be an air leak.. the injectors inject straight into the inlet ports... if there is un-metered air getting in, all cylinders will run lean or badly..
It could be that it has un-learnt it\'s learnt tune. It might need taking for a drive... They come set to run a new motor correctly, but as they wear, or the exhaust or injectors or the air-cleaner get dirty, they self adjust to compensate, and they remember that learnt compensation for the next start up.. If you take the battery off, a motor that had been running fine compensating for slightly low compression say, won\'t run right afterwards till it\'s been driven through a relearning drive or two.
Also.. that would have a wasted spark ignition system by the sound of it.. so if one coil or half coil was buggered, two cylinders will be effected by it.
