Hey guys,
I have a 98 wrx ra and trying to get it fix issues for warrent. All the indicators work apart from the drivers side guard repeater. Doesnt work while indicating or using hazards.
Ive switched bulbs and housing with the other side with no luck. As it is only one indicator i doubt it will be fuse?
What else could it be? wiring seems to be fine since it goes into loom.
Any suggestions?
Cheers,
vin
 lachlan said:
just run another wire from the front to it some how
+1 If there is no Power at the Bulb Socket Contacts? Also test the Loom Plug end? Clean all Loom Plug/Housing Contacts, then test again.
If still no good then tap/splice into the Front Drivers Indicator. Could even cut the existing Wiring and re-route it, so it\'s still Semi OEM.
  • 3 weeks later...
Yeah was only getting 9v, i suspect grounding issue. Just rewired from front indicator.
Now its got 99 problems but a indicator aint one.
  • 6 years later...
Hi,
Did you own a blue1998 wrx ra the number plate was 5OLID. The number plate is now hjt777.
I'm looking at buying this car and I wanted to know some history on it. Message me if you can 0275808131
    574.7k
