CEL code 65 and 66
tydon
It won't be BBOD etc related if it refuses to even fire
I'd be looking at maybe AFM or something else completely. I had a fuel pump fail but could just manage enough grunt to prime it, start it, and run for a second or three before sputtering and dieing - drove me mental trying to figure out
  • 4 weeks later...
  • 5 weeks later...
  • 10 months later...
Fans should both be pulsing in test mode. Maybe check the fan fuses in the engine bay fuse box.
ECV - Exhaust control valve, drivers side. Should see the actuator rod moving in and out:
IACV - Intake air control valve, drivers side under the TMIC. Again should see the actuator arm moving in and out:
Failing that there's some great info in this thread.
Yes both EVC and IACV move
So went for a drive after work today and I will feel sluggish and the boost gauge will read 0.5 bar and then get to about 4500 rpm and then rise up to 1.0 bar when it rises I can feel a thud when it does it but there was times when the boost would do nothing and it would shoot up to 6000rpm.
When it is idling it will just die sometimes
