clutch issue
hey everyone
ive just replaced my motor in 99 b4.....
i have problem with clutch now.
i kept geabox in the car and didnt touch it.
i have put my flywheel clutch bearing etc on new motor and fitted everything....
now my clutch pedal has no resistance at all. and just sits on the floor.
also the piston from the slave on gearbox is pushed right forward and i cant pull it back..
any ideas?
Use a small clamp to press the piston back in, must be semi seized. If it's been unused for a while the clutch has just lost pressure and needs a bleed as Andy said.
Leave the clamp on while you bleed it, with the piston held right in. Can even unbolt the slave cylinder and tilt it while you bleed to help any air bubbles get out.
