Wheel allignment specs/preferences
I got my first proper wheel alignment yesterday in the BH5. After replacing all suspension bushes, tie rods, rack ends, ball joints and bearings. I've read a few threads on here covering camber and toe, but most seem to lean towards stance and fitting bigger rims. I want to know peoples preferences for handling, street and track. Cornering/oversteer/understeer versus straight line traction/braking etc.
I have Cusco adjustables, stock sway bars (for now), running 225/40R18. With OEM non-camber adjustable arms in the rear end and the OEM eccentric front camber bolts. This is what I'm trying currently, although I would like to get some adjustable rear arms:
Whiteline recommendations:
whitelinewrxwheelalignment_zpsee3a20a4.j
Autospeed article on improving WRX handling
http://www.autospeed.com/cms/A_111375/article.html
Both taken from this thread started by evowrx:
http://clubsub.org.nz/forum/showthread.php?35280-Function-vs-form-happy-camber-medium&highlight=camber
Here's all five original 'Rex On Rails' documents from Whiteline:
Part 1 - WRX standard suspension and wheel alignment adjustments:
http://www.whiteline.com.au/articles/AS_Rex_on_rails_1.pdf
Part 2 - WRX Rear sway bar upgrade:
http://www.whiteline.com.au/articles/AS_Rex_on_rails_2.pdf
Part 3 - WRX Anti lift/castor kit:
http://www.whiteline.com.au/articles/AS_Rex_on_rails_3.pdf
Part 4 - WRX Front sway bar upgrade:
http://www.whiteline.com.au/articles/AS_Rex_on_rails_4.pdf
Part 5 - WRX Adjustable rear camber kit:
http://www.whiteline.com.au/articles/AS_Rex_on_rails_5.pdf
  • 4 months later...
@Rosssub keen to find out how these allignment specs are working for you? Happy with it? I need to get one done very soon and am thinking of trying some of these settings.
Have a 19mm sway bar in the front and 22 in the back though. Other than that, BC golds and whitline endlinks.
