Hi all,
After having my cambelt done at Winger Subaru Greenlane last Wednesday, the car seems to not boost as much and is a little laggy?
They did an engine diagnostic to try and get rid of the stupid engine check light because of my knock sensor. It is since then that the car just doesn't seem to play as nice :-[
What do you recommend I do? I will definitely be ringing Winger tomorrow but are there any ideas to what it may be?
id say its to do with your knock sensor...
Has it actualy seen a drop in boost (have you checked on gauge if you have one?) or does it just feel less responsive.
Sensor for my old GT cost me $120 and installed it in 20 mins in the dark on the side of the road. Pays to ask how hard stuff is before you pay someone else to do it.
Twin turbo is a bit harder to install Ben....
If they reset the ECU then it will most likely drive different, as it will have reset the fuel and ignition maps back to factory.
Does it then learn new maps and what not?
Yup. Just takes time.
Oh ok thank goodness for that!!! It did still feel a bit sluggish lol but as long as it gets better I am happy.
Such a nice car to drive and is actually quite economical if I dont want to boost all the time.
;D ;D ;D ;D
    574.7k
