Had an idea of making up a 3 inch exhaust using V Bands for joining downpipe to mid pipe and mid to muffler.
Bad idea?
Anyone have some success stories about going at a V band with a Mig, assuming warping is the biggest worry?
Are V Bands up to that kind of job? Most of the exhaust weight should be on the hangers but I really have no idea hence im here.
I have a dsr v band from d/p to rear section. Leaks a bit but liveable. I see scarles sell a copper gasket for them unsure if they work or not. Complete ease for fitment tho. Tig iirc and definitely holds weight of exhaust.
Yea so im real keen on the ease of fitment side of things. ill look into those copper gaskets that sounds like an idea. only have access to Mig so that will have to do.
Tig would be nice, stuff like this looks so damn good.
I made my exhaust using V-bands and mig'd it together. haven't had any issues with it, no leaks etc. the v-bands I used were fairly decent ones, they had an extra lip on the inside which sits inside the mating flange so creates a better seal than the more common ones that have 2 flat faces that can slide against each other...
