Idle/Misfire issue has me baffled
kris_pran
The golden run of not having any issues has come to an end for my v7.
There i was happy cruising along in a 50 zone when suddenly the car began hesitating, didn't want to rev at all, afr's dropped to 12.5/12.7 usually at 14.7/15.0.. Thank god i was just around the corner from my place so i managed to limp it home.
Things ive done:
1. Can hear fuel pump priming prior to start up
2. Changed iridium plugs back to stock ones i had on previously
3. Tested coil packs, disconnected one by one and observed idle. Two of the coil packs i felt that weren't changing the idle at all were replaced and the end result ive noticed a slighty improved idle but still the hesitation to rev remains. afr sits at 15.7 at idle before was off the charts 19/20
4. No leaks coming from any of the injectors (id1k)
5. Zero air leaks. Seriously! ok maybe a very minor one from up-pipe to manifold joint.
6. No cels
Its def idling on 4 cylinders, before it felt like 3 prior to me doing 3rd point above.
Suggestions/opinions please :)
Cam position sensor? Also check your loom, particularly the drivers side main connector, see if it's full of oil - sign of failed AVCS sensor and causes all sorts of weird issues if the oil makes it to the ECU.
Complete failure will through a CEL. But they can be out of whack far enough to cause running issues without throwing a CEL.
The ECU will give a CEL if it sees a voltage outside a specified range for each certain sensor. The sensor can be way off, but still within the specified voltage range.
Unplugged MAF, ran worse-ish, Logger registers correct voltage readings for MAF and ait works.
Checked loom for visible signs of oil - negative.
What a nightmare haha took it for a small drive on my street, sounded like 3 cylinder exhaust tone. Might be time for compression test?
