CVT Trans service
angie
Recently bought a BR 9 wagon. Runs nicely. Just out of warranty so when, at what age or at what mileage, would a full transmission 'service' be required? And who in Auckland offers an excellent service at a reasonable price? Thanks
Sofar all the info I have seen suggests that the CVT merely be inspected. Nothing about replacing oil etc at certain intervals. Who inspects the gearboxes? Is it checked at a routine full service or is it checked at an auto trans specialists? Ex Japan, service history to 35ooo km at Subaru Tokyo dealer. Just had full service here but I dont use Wingers, I use my local MTA/AA approved workshop. Mainly because the places like Wingers are too inconvenient to get to easily etc.
I'm not sure how you would thoroughly inspect the box without dropping it out of the car and opening it up.
In which case you may as well just do routine maintenance until it eventually dies...
if i were you, with a Jap import id get it serviced ASAP and then from there get it serviced every 50,000km or so. Its cheaper to service a box regularly than to replace it.
Id get the dealer to service it, or at least get them to supply the correct fluid.
Theres an inspection bung at the back of the transmission 6mm or 8mm alen key and really only need to change cvt fluid 100,000kms but if ypur towing need to inspect every service and check the color and smell
According to owner's manual the CVT never requires servicing, which I take with a large pinch of salt.
As far as Auckland goes try Kaspa Transmissions. I have no idea if they do the Subaru CVTs specifically, but they definitely have CVT experience.
Thanks.
