Hello all!
Maad
Hey guys just recently bought my sf5 forester which is also my first ever subby. Absolutely love the car just had a couple of questions.
Cant seem to find one with the search but is there a comprehensive post about what is and isn't interchangeable from impreza (wrx/sti) to foresters?
And also i have tracked down the sti injectors, ecu and maf. I also have a td06 20g, if i keep the boost at a relatively sedate 10 - 14psi will the over all increase in air volume still require tuning or will it be all good?
What year is the foz? Or pics would help just host on photobucket or the like and paste the img tag on your post. Td06 20g will need a tuneable ecu and bigger injectors to be worth doing. If you dont you will end up with a slower car with soggy response. Likely blow the bottom end with the bigger turbo too.
If its v3/4 throw sti stuff onto it including a vf## and should be fine but kiwi fozze will confirm.
Yeah, bugger.
Some of the sf5b foresters have a purple sticker AFM, others have yours, which is v5 era ECU and AFM. These really don't like mods, unfortunately the orange AFM/yellow injectors/ECU swap is off the cards.
You can swap in a vf22/23/24/30/34 turbo with no issues, as i'm sure you will have noticed it running out of puff at about 4500rpm
Unfortunately, to really squeeze some impressive power out of these, or extensive mods, you'll need to go to a link ECU, or a reflash through STM
 kwi_fozze said:
Yeah, bugger.
Is the non sti v5/6 a7 ecu an upgrade? Seen people saying the foz ecu is detuned further. Throw a vf24/28/29/39 on it itll suit ecu better.
 kwi_fozze said:
Not stumbled across it myself, but its worth a shot. I know for a fact the j2 ECU has audible detonation at idle because of the difference in CR
Guess factory figures would tell all. Know our p2 2000 foz was far slower than v5 wrx and wasnt just weight related. Yep j2 wreaks havoc pita that.
Rear swaybar even just swapping to wrx one will help handling a ****load.
Mines pretty sacked at the moment. Want to raise it a little but not all the way back to factory height. I can get really good prices on suspension but just not sure what to get. Im not too fussed about making it a rocket ship. Just want it to go a little harder and handle like a demon.
Rev b *might*
Rev c does
Rev d is totally reflashable.
Forester struts with low springs, or impreza struts with lift springs will set you about right.
But yeah, big swaybars, front and rear strut bracing, a k brace in the front, in fact all of the chassis bracing LOL
 kwi_fozze said:
Rev b *might*
Rev c does
I've got a Rev C and was under the impression the only way to tune was through a Link ECU - are you saying there's a way to reflash the stock ECU?
