Help with rear diff query
Phewsion
Hey All
Car: 2002 Forester XT Auto (SG5)
Transmission Code: TV1b5mbzab
I'm hoping someone can point me in the right direction or has the info I need, searching google for the Trans code just gives me 6 pages of Russian sites that translate badly
I need to replace the rear diff, it's making a metal on metal rubbing noise and the fluid has metal flakes in it (looks like glitter)
I went to strongs but they have 4-5 different diffs and he couldn't tell me which one was mine
I need to know the Final Ratio (4.111 or 4.444) and if it's LSD or not
Also how hard would it be for me to do this.
Jacking the back of the car up will tell you both these things in about 30 sec .
Need car in nuetral with hand break off . Try spin a wheel . Does other wheel spin same direction ?lsd . Opposite direction or not move is open diff . Put a mark on the d shaft and a mark on a wheel . Turn the drive shaft around as many times as it takes to make the wheel do a full lap . 4 and nearly a half is 4.4 . Just past 4 is 4.1 . Just under 4 is 3.9
I did the wheel spin and both moved the same direction, I thought it was LSD but wanted confirmation as the place I got that info from people were commenting that it doesn't always work, but I was unaware of the the driveshaft trick
I don't have a garage so I'll wait for the weather to nicen up first, Thanks for that info though :D
