Swaybar woes
Sup y'all,
Installed a new Whiteline 22mm front swaybar with grease-less bushes the other day. Got some new endlinks from BNT - as suggested by the forum previously.
The problem is the swaybar keeps moving (towards the passenger side) even after slow/normal driving around town. As a result the endlinks end up being 'uneven'. ie the left endlink ends up vertical, and the right side at an angle. like / and |
So the swaybar is moving, which can not be good.
Should the swaybar bushings and clamps technically be enough to hold the swaybar in place? I don't have a torque wrench so using a 12mm socket wrench. Or am I going to require additional Whiteline lateral locks (collars) to stop the swaybar moving??
I didn't have this issue with my rear swaybar.
Ideas???
RR
What exactly are you referring to by D links?
My rear without the clamps would still have most of a fingers width of space at each end to move laterally before the bend in the bar would stop it. But thats nothing compared to the movement the fronts can have. The BE/BH ones look similar other than the big hump on one side.
Edited by Andy_Mac
BP/BL's (and maybe BE/BH?) use silly little swaybar links, most other Subarus use a grunty D-shaped link that effectively prevents most lateral movement of the rear sway bar.
Got some Whiteline lateral links (KLL122) which hopefully will do the trick. After install and one quick drive the bar seems to have stayed put. Now just to deal with the groaning noises. I assume its the bushings, and I'm using Whiteline's new 'greaseless' bushings. I'm not convinced they work. Anyone else have experience with greaseless bushings? Should I just put grease over the "cloth-like PTFE liner"?
Original swaybar and endlink
L end link - near vertical position
R endlink - being pulled over to the left
Rear D link
Yea thought so, would have called that a C link if I had the master car part naming job.
You can always get the solid endlinks rather than adjustable which more often than not have a fairly solid bush and a bolt going right the way through so should give similar stiffness to the D link.
http://www.whiteline.com.au/mobile_product_detail.php?part_number=KLC30&sq=20630
Half of it will be what way you enter your driveway. Without my clamps I could check it and it'd be centred before going in the drive and after that it'd be pulled off to one side, quite a prick of a driveway though.
Pfft, back on your meds man, totally a capital C
