Intercooler swap help
El_Chado
Hi Crew, I purchased an STI intercooler to run on my SG5 forester. Everything fits perfect. Only minor issue is that there is a hole in the bottom of the STI intercooler for a sensor, which my old intercooler doesn't have.
What's the best thing to blank this off with?
Has the hole been tapped? Could just throw a bolt in there would be the easiest thing to do, if you're worried about leaks with that solution, you could make a gasket using gasket paper or an old metal gasket. OR, you could buy an AIT sensor and run a badass air temp gauge.
Wtf is 3/8 BPT ?
Do u mean bsp ?or npt
Theres not enough meat there to thread something into it properly .
Weld it up if your worried . Nut n bolt it with what ever fits . Grind the bolt head down a bit . Put the bolt in from the inside out . Seal with 3 bond /silicone . Lock tite it or double nut it
