Manual conversion
toad
Hey, long story short I got a 1997 forester which I got as payment for fixing a car and it was auto but the previous owner had started a manual conversion using bits out of a bc5. He put peddle box in and that's all. I have the gearbox, diff, driveshaft, halfshafts, a complete rear subframe assembly hubs etc aswell, everything needed to do the manual conversion. My question is do I use the hubs, halfshafts and what else out of the rear subframe of the bc5 would I need or can I use some of the Forrester gear? I also have a complete front subframe with hubs etc as well. How much of that would I need for the front or can I use the Forrester gear. Not sure if the halfshafts are the same length and the trailing arms etc. Any help would be awesome.
Thanks
GB Clutch stuff & manual shaft is it I think
never done it myself but the rest should be fine if you get a matching diff ratio GB otherwise use the diff that came with the box?
the rest is surplus iirc someone will confirm hopefully
there might be a guide in the gearbox/ drivetrain section (check the Faq @ top of every section
