OBD2 Bluetooth Scanner
ToomTom
Has anyone used an OBD2 scanner with the torque pro app? I can get a connection to the ECU using 'ISO 15765-4 CAN (11 bit 500Kbaud)' but I get absolutely no data from it. I've seen these setup in my current car before with it working but I just cant seem to do it.
It needs to have a different chip in it. The only B/T adapter I found was from the UK and would cost a small fortune ( a few hundred dollars with postage). You can get a cable with the right chip in it to work with your car. I will see if I can find the thread that has the info in it (it could be in Dumb question thread).
Edit:
As kiwi_fozze was saying if it has the ELM327 chip it won't work
I think this is the website (haven't had time to double check if it is the right one)
http://www.obdkey.com/obd_orders.asp
Edited by SpeedySub
Edit:
Thanks mate, I was hoping to use the cool features but Subaru :P. Oh well ill live!
