Leaky rear washer
thewabbit1
So, this is a possible 'dumb question thread' question, but ima ask here regardless. My BH5s rear wash jet leaks under moderate boost, and my front ones dribble under vigorous cornering. How do I fix this?
The mechanic said it was an easy fix but I opted not to get him to do it as easy non mechanical fixes = I can do them.
 Andy_Mac']The ****s, is that actually a thing. How is that even possible?
Its like its incontinent... thankfully its only washer fluid
[quote name='sobanoodle said:
Haha reminded of my old BG, rear wiper jet would start pissing everytime I go uphill.
It always seems to happen the worst just after i've cleaned it too
 ADIKT said:
My GF8 did it up hills and when my right foot was planted.
Ended up removing the water feed to the rear wiper and redirecting it towards the top mount with some cheap sprayers
It is tempting... cause I only seem to use the rear washer to clean the marks from it dribbling...
But I do like bars bugs, not sure if my TMIC would like it
There is a valve in the line. Looks like a small cylinder with barbed hose ends. It's a ball held in place by a spring. With age the spring goes to **** and so releases at a lower pressure.
You can buy them. IIRC I got a replacement for mine from Davies via Repco.
Or you can scavenge one from pic a part but they'll most likely be **** as well
Ah, cheers mate
