WRX STI A 1997 - Cam Sticking after rebuild
Arcology
Looking for some divine intervention.
WRX STI RA v3.
Right hand exhaust Cam shaft sticks, even if you only do up the font cap to just above finger tight. All other cams move freely.
Rebuilding after head gasket blew. Heads have been planed.
Even if the other two caps are loose. We have cleaned and oiled all surfaces and there appears to be no issues, but obviously there is.
Any advice on what it could be or if we should consult someone with more than 1 months Subaru experience please let me know.
Cheers in advance.;)
Have you checked clearance? i.e. measured cam journal and i.d. of bearing cap with it torqued up? on some other engines I've built these have been too tight and just a quick hone out has sorted it out.. also check you have the right cap as they're all different as they are machined as a set.
