Oil Temp Sender
thewabbit1
Hey All
Looking at getting a gauge cluster for my BH5 and it comes with a oil temp gauge but no sender. I've read that there's a blank plug somewhere around cylinder 3 with an 8mm(?) allen key which is perfect for oil temp. Now in terms of sensor, what do I need? I'm reasonably new to this, so would a sender like this work?
I have searched the forum but "oil" doesn't work, "temperature" and "gauge" are pretty generic and "sender" doesn't show much and all four of them together gives me not much help!
If anyone has any light on the subject then please share!
This pic shows the OEM oil pressure switch and adapter bung removed. The other port you mention is circled, probably be easiest to get hold of another adapter bung for the new sensor:
Not sure if the cheaper sensors are any good, but it will work.
