JDM 2007 BP5 Running rich
killervq30de
Had the car dyno at the recent AKL ClubSub dyno day and the car is running rich .. not a big surprise when I think about the lower fuel economy I seem to have compared with other people on the forum.
My car is JDM 2007 BP5 with 92,xxx KM's on the clock .. where do I start to troubleshoot and resolve this AND which ones are going to have the best gains
1. How many O2 sensors are there.. are say the fronts more common to fail than the rears so start there .. which ones play the biggest factor in the fueling
2. Knock sensor (unrelated) but on my old A32 Maxima knocksensors were common to Half-fail and not throw a CEL.. timing just wouldn't advance as much. Subs?
3. MAF? is that being dirty a factor? Airfilter should be ok .. I get it serviced at Winger Sublabs mainly for warranty but also I've had a good run there
4. Fuel filter? Is it replaceable - probably not a factor either though
5. Spark plugs - they'll be done at the 100k service (i guess)
Anything else?
  • 4 weeks later...
ok.. late late reply
I get an average of 400-500(tops) on a tank around Auckland, which can be quite hilly in places. I drive it like its a turbo car.
On the economy meter thing I get around 7-8Km/l around town and long distance (can't recall but) 12Km/l
So again from my top post, what I can do/replace to get some economy (and power) back. I got flash/tune until my Mechanical Warranty is up next July.
Edited by killervq30de
yea thats pretty bad economy ay. Power isn't all that bad considering how low everyone else got that same day.
Why not just get an e-tune. If you keep everything else stock they wouldn't know any better. You'll get better economy and a small bump in power. Can easily get an extra 1-2psi out of it without needing to worry about extra cooling needs.
 KarlGTB said:
I think my best average ever for a tank on the factory trip meter is 10.7 km/L. Mines auto though. I came from a BG GTB so I thought I was actually doing quite well, maybe not!
Hopefully not long distance otherwise your round town must be as bad as mine?
Rather not mess with the tune right now. I'm hoping its dieing O2 sensors. It's at 93kms now and I got it at 55kms, economy seems to be getting worse but it's always been 7-8km/l
What's your journey like, what's the average speed and distance? It looks pretty normal to me...
My old 04 GTB auto got about 500km per tank on 50km a day motorway trips in traffic, that was with a light foot on flat-ish land. Total open road it would get to 12km/l and 600-700k per tank.
So maybe my consumption is normal? But the dyno chart shows its running rich? My car was probably bit heat soaked, as I drove there, parked up for not long and then dyno'd without airflow. Wouldn't think it would make the ECU run the car rich though.
you can get wideband o2 sensor for $300 if you wanna monitor it yourself on the go. New factory sensor can be brought from partsouq
o2 sensors are one of the general causes for rich fueling but it could be anything (I'm not super familiar with the newer stuff but injector seals are common leak points on early engines)
my old legacy with rich tune gets 6-7 km per L lol
