Bleeding your clutch system - How do you do it??
So a mate and I replaced the clutch slave on my BG5 over the weekend, easy job with no problems until we went to bleed the replacement.
Here was our unsuccessful process:
- Fill the reservoir with fluid.
- Open bleeder valve on salve.
- Push clutch to the floor.
- Close bleeder valve.
- Pull clutch up from floor.
- Repeat until all air is removed from the system while topping up the reservoir as necessary.
Can anyone tell me why this wouldn't work?
After a lot of googling, someone suggested using an F/G-Clamp to hold the pin in on the slave and to hold the slave upside down to move all the air up so it would come
out easier. We did this and after 10mins of bleeding using this method we were good to go.
The thing is, we don't really understand why this was necessary and would love it if someone could explain a little?
In my googling it also appeared that a number of other people were facing the same issue as we were and the only other
solution was to use a vacuum bleeder, but surely this shouldn't be a necessity?
The slave is mounted with the piston pointed up... the bleed nipple and the feed hose are lower than the piston... so fluid
will come into the back of the slave and right out the bleed nipple leaving bubbles higher up present.
Yep, definitely get that part but why the need to clamp the piston down?
The inside of the piston/plunger can be full of air, forcing the piston in pushes any air out. Also the piston can be pushed too far out when bleeding without the clutch fork to stop it.
Edited by Rosssub
yea was in a different (diy / maintenance) section I'm having a tidy up putting all the same stuff in the same place etc
feedback & ideas welcome
is is the Gearbox section supposed to cover clutch - Box - diffs and axels + hubs? or does it stop at the diff?
