Headlight covers source (& more)
Joker
sweet good to know dont think I've ever seen them mentioned is all :P (I don't see everything either & search button works now so yeah...
edit : seems like at least 7 of you knew :P
 Johnnynz said:
Just FYI they clip onto the headlight. Not a weight saving there.
Actually there is a huge wait saver for race car, you just do what I did, grab a light from pick a part rip it apart, keep the plastic rear and bolt cover directly to that. Then it looks like a light with cover but is only plastic. Granted this doesn't help when it's dark but during daylight its fine.
Cant you just buy a false light? I have seen a few around at the track with a flat surface and holes in it.
Not disagreeing with your idea, just seems like a bit of a stuff about.
Yeah you can, but when I did mine I couldn't find one for sale, so did this instead, certainly would have been easier, and if I could have found one I liked, I would have just bought it, would have saved me money too, probably.
I just cabled tied mine to the radiator support (through those clip tabs), then drilled a hole in the corner where it meets the guard, and used a screw to hold it in place (with a rubber bush behind the cover to stop it from being tightened right down and cracking).
