Hi guys, so I'm slowly gathering bits (thanks Clint) for a single turbo conversion in my BG5.
I've done a bit of research and the conversion itself isn't super difficult but I'm struggling a bit
with engine specs and what limitations I might have with the EJ20H.
I gather the heads don't flow as well, the cams aren't as good as the EJ20R and the compression is higher meaning a v3/4 STi ECU might wet itself.
A few key questions below...
a) Looking to see if anyone here has successfully done this to an EJ20H?
b) Can I solve the compression issue with thicker headgaskets?
c) Do I just run the TT into the ground as is and drop in an EJ207 sometime in the future?
Thanks!
Koom's post from the above link:
 Koom said:
Thats one of the harder ECU conversions and I don't believe that a straight swap is worth it i.e. using equivalent WRX 4-plug ECU and keeping the grey injectors.
You need to swap about 80% of the pins on the ECU and change a couple of wires around under the bonnet.
The old pinout list for this conversion is this one;
But I also have a colour coded one here which has a few more instructions on it: https://www.dropbox.com/s/fo77a7bk8l51eg2/ECU%20Pinouts%20BC5%20BG5a%20WRX%20%284%20plug%29%20-%20Single%20Swap.pdf
But if I was to ever approach this conversion again myself, the only way that I would ever consider bothering with the work would be to use a 3-plug STI ECU and convert to V3/4 STI single turbo. So would also require yellow injectors, correct AFM etc.
Takes more work and parts to achieve the conversion but gives a much better result.
The electrical side isn't much different to swapping in a 4-plug WRX ECU (Tip: 3 of the 4 plugs on the 4-plug ECU's can be used for a 3-plug conversion as they're the same plugs. You just leave out the 12pin plug).
In this case you'll need to use a V3/4 ECU pinout list to compare and swap around the relevant pins. Some sensors may also need to be changed but if you buy a complete manifold then most of that issue should be solved.
No worries man, but yeah looks like a headache for minimal gains. Be better to change to a complete EJ20K V3/4 STI engine/ECU and re-pin or re-loom for probably less effort, better gains and a matching CR.
Or like you say hold off and go the whole hog, V7 STI engine/ECU/loom/cluster. It's just jumping in at the deep end if you haven't done much engine/ECU wiring. Then there's the cost on top.
Yeah it's all pretty new as far as actually doing the work is concerned. A v7 STi complete swap would probably be more achievable in some areas and give me the reliability I want as well.
Just a $$ thing but would rather do it all right the first time and the TT is keeping me relatively happy for now. Finally got the shell I want so just a matter of filling it with the right goodies.
I didn't see mention here what EJ20H was in use. Is it a BG5A HLA (ribbed rocker covers) 20H, or a facelift auto solid lifter (smooth rocker cover) 20H?
I'm going to assume it's the former hydraulic type. I've come to love these engines over the years, I used to hate the hydraulic engines, but I see their charm these days. Good old school blocks that make an awesome noise, and can still be made to make a bit of power. If it's a good block, don't feel obliged to pull it out and put something wanky and modern in it when you don't have to.
Just use a WRX ecu for the conversion, or better yet, a link if budget allows (even an old possum link can be had for about $200 these days). If it's a 4-plug loom, it will not be pleasant you re-pin, but you can choose to go to either a 3-plug or a 4-plug. Going to a 4-plug is probably the harder choice, as you'll have to revert to older sensors (though will let you run V2 WRX ECU's which are perfect for that block/combustion chamber/head flow etc), going to a 3-plug would be fine. in which case, a V3/4 WRX Auto/wagon ECU will be the go, and should make the same power as the factory BG5A ECU.
  • 2 months later...
BG5B Means you have the solid lifter facelift EJ20H. No 4-plug ECU, this conversion should be exactly the same as a GTB 20R converision, only you're limited to V3/4 WRX AUTO ecu's that run the smooth 20G with grey tops and i think purple AFM.
  • 9 years later...
ive just got a new bg5a with a 20h sad part is primary turbo is cooked, however i have all the bits to single it, although im wondering if i can use the 4b ecu ive got apparently its an auto sf forry ecu, if possible to use what does it invole any help would be great please and thankyou
OP isn't a regular here anymore and I'm not ECU savy : but the 1st question is But why?
is your car Auto?
    574.7k
