GC Impreza - STi 'Lowered' Pinks or STi 'Standard' Pinks
Hi guys
Was having a bit of a browse around the net and found these part numbers and details for GC model Sti springs
Might be handy for someone.
Standard STi Pink :
STI COIL SPRING (FRONT) 35 : ST2040055010
K=35 (3.6kgf / mm, 201 lb/in), For Sedan WRX-RA.
STI: COIL SPRING (FRONT) 39 : ST2040055000
K=39 (4.0kgf / mm, 223 lb/in), For Sedan WRX-RA.
STI: COIL SPRING (REAR) 30 : ST2230055020
K=30 (3.1kgf / mm, 173 lb/in), For Sedan WRX-RA.
STI: COIL SPRING (REAR) 32 : ST2230055010
K=32 (3.3kgf / mm, 184 lb/in), For Sedan WRX-RA.
Lowered STi Pink :
STI COIL SPRING (FRONT) 34, -30 : ST2040055060 'LOWERED'
K=34 (3.5kgf / mm, 195 lb/in), For Sedan WRX-RA & Coupe WRX-R, Use with genuine Struts, Color: Painted in Cherry Red, 30mm Drop.
STI: COIL SPRING (REAR) 30, -30 : ST2230055100 'LOWERED'
K=30 (3.1kgf / mm, 173 lb/in), For Sedan WRX-RA & Coupe WRX-R, Use with genuine Struts, Color: Painted in Cherry Red, 30mm Drop.
