Sti springs with bilsteins
I probably wouldn't go with the pinks if I did it again, comfort is barely any difference to how it was stock but being another 10mm or so lower would have been better.
There's a long winded list. Sobanoodle had a table that was alot simpler but that was in the 41 thread which was wiped.
Use ST2033021000 as Front Spring for:
- Legacy B4 2.0GT AT Applied A~F
- Legacy B4 WR Limited 2005 AT Applied C
- Legacy B4 3.0R AT Applied A-B
- Legacy B4 3.0R MT/AT Applied C-D
- Legacy B4 3.0Rspec.B MT/AT Applied C~E
- Legacy Touring Wagon 2.0GT AT Applied A~F
- Legacy Touring Wagon WR Limited 2005 AT Applied C
- Legacy Touring Wagon 3.0R AT Applied A-B
- Legacy Touring Wagon 3.0R MT/AT Applied C-D
- Legacy Touring Wagon 3.0Rspec.B MT Applied B
- Legacy Touring Wagon 3.0Rspec.B MT/AT Applied C~E
Use ST2033021010 as Front Spring for:
- Legacy B4 2.0GT MT Applied A~F
- Legacy B4 2.0GTSpec.B AT Applied A~C
- Legacy B4 2.0GTSpec.B MT/AT Applied D~F
- Legacy B4 BLITZEN 2006 AT Applied C
- Legacy B4 tune by STi AT Applied C
- Legacy B4 WR Limited 2004 AT Applied B
- Legacy B4 WR Limited 2005 MT Applied C
- Legacy Touring Wagon 2.0GT MT Applied A~F
- Legacy Touring Wagon 2.0GTSpec.B MT/AT Applied A~F
- Legacy Touring Wagon BLITZEN 2006 MT/AT Applied C
- Legacy Touring Wagon tune by STi MT/AT Applied C
- Legacy Touring Wagon WR Limited 2004 MT/AT Applied B
- Legacy Touring Wagon WR Limited 2005 MT Applied C
Use ST2033021020 as Front Spring for:
- Legacy B4 2.0GTSpec.B MT Applied A~F
- Legacy B4 tune by STi MT Applied C
- Legacy B4 BLITZEN 2006 MT Applied C
- Legacy B4 WR Limited 2004 MT Applied B
Use ST2033021030 as Front Spring for:
- Legacy B4 3.0Rspec.B MT Applied B
Use ST2038021000 as Rear Spring for:
- Legacy B4 2.0GT MT/AT Applied A~F
- Legacy B4 2.0GTSpec.B MT/AT Applied A~F
- Legacy B4 BLITZEN 2006 MT/AT Applied C
- Legacy B4 tune by STi MT/AT Applied C
- Legacy B4 WR Limited 2004 MT/AT Applied B
- Legacy B4 WR Limited 2005 MT/AT Applied C
Use ST2038021010 as Rear Spring for:
- Legacy Touring Wagon 2.0GT MT/AT Applied A~F
- Legacy Touring Wagon WR Limited 2005 MT/AT Applied C
Use ST2038021020 as Rear Spring for:
- Legacy Touring Wagon 3.0R MT/AT Applied C~E
- Legacy Touring Wagon 3.0Rspec.B MT/AT Applied C~D
Use ST2038021030 as Rear Spring for:
- Legacy B4 3.0R MT/AT Applied C~E
- Legacy B4 3.0Rspec.B MT/AT Applied C-D
it's just a standard 3L with triptronic Andy.
After editing. I've been looking for my car type and what it actually is. I have no idea what it is now I have looked more into it...
also according to GOVT it's a station wagon when mine is a sedan...
It's a 2004 Subaru Legacy
5 AT transmission
7at0gf8bx16012255 Vin
Chassis is ble - 012255
engine is ez30dhlbge
my plate is jny567..
This is weird ay
I'm looking at things and it might be a 3R. It can't be the b spec as it doesn't have leather seats right?
Edited by B4H6NA
WHAT IS MY CAR
Yea the NZ rego system is pretty good at ****ing it up. Not completely sure on what had what with prefacelift spec B's. What rims has it got? The multispoke 18" ones?
Spec B or not, the part numbers are the same for the auto.
There are the part numbers for the ones you'll need.
F: ST2033021000
R: ST2038021030
Info stolen from here:
http://forum.liberty.asn.au/viewtopic.php?f=19&t=27480
Edited by Andy_Mac
Saw it in the shop and was talking to the guy. But i'll be doing more research as it just didn't seem right. Should be 22mm rear 20mm front
And it's thicker in the rear for mine as the centre of gravity is closer to the back than the front
I might be wrong. Would you shed some light on them? What to get and why? Might be good to get some different ideas. No information is ever unhelpful unless it lies. I sbould hope subaru actually knows what they are doing...
 sobanoodle said:
Shouldn't it be the other way round? Thicker front/thinner rear?..
For the front you can use a stock Tribeca bar - 25mm from factory.
Wouldnt that promote more understeer?
Front-wheel drives often benefit from a upsized rear sway bar
Rear-wheel drives that understeer often benefit from a upsized rear sway bar
Rear-wheel drives that oversteer, or pick up an inside rear wheel and spin it, often benefit from a upsized front sway bar
In four-wheel drives, combat understeer with a thicker rear bar, or combat oversteer with a thicker front bar
