EZ30 BP Legacy CEL (cam position)
agusta
Hi I posted a thread a while back in the legacy forum but problem is developing a bit further.
A month ago my CEL came on with al the other blinky lights, local garage plugged in scanner found fault and replaced cam position sensor bank 1.
It went well for about 300ks and then it started again. Now it chucks the CEL every other time, but it will miss without a CEL and sometimes stall at idle.
Put the scanner back on it. And the same fault has appeared.
Just wondering if anyone has encounted this so we can cut down some time fault finding. Genunine subaru sensor was used on the first change.
thanks
