Wheel Machining - Mutli Stud Conversion
Hey guys,
Might be a very silly idea/question, however is it possible to take a later model 17x8 5x114.3 rim and machine to incorporate a 5x100 stud pattern?
I only ask as I'm finding it difficult to find a 17x8" or 17x8.5" in a 5x100 in the right offset to be able to fit with out the need for flares. I either need to run a hub-centric 25mm 5x100 to 5x114.3 adapter/spacer, which in turn will result in needing flares and panel work or purchasing exactly what I need in the right stud pattern and offset which seems to be quite pricey.
Was hoping I could pick up a set of the enkei 17x8 5x114.3 53 offset and convert to 5x100.
I understand the later wrx had a 5x100 17x8 in a 53 offset, whether they clear brembo calipers I'm unsure and locating a set of them is proving to be difficult.
Any help/advice would be awesome.
Cheers.
Any decent wheel will be made for the number of studs and there wont be enough meat anywhere else in between to make an entirely new set of holes. And no u cant slot the holes
Rotas n such will have a mile of blank space for new holes as theyre a generic casting
Wheels can be filled and then redrilled, it is expensive and finding someone to do it now is pretty hard,
I do have some Super Advan SA3R's that i may let go for the right price, in the size your looking for
Are those the tri-spoke one's?
If so, not really my cup of tea sorry.
