yeah its been done a brazillion times in all makes & models
(sure it seems easy ground the neutral wire & bung the hardware in) but its never quite that easy is it? across the gens & models?
or please point me to nearest thread because I cannot seem to find one anywhere
or help us make one with pretty pictures & details & stuff, even if it is for one particular model etc
I want to add it tot he FAQ section
  • 1 year later...
BD/ BG5's RS-B RSB GT-b GTB
BG9 (NA)
BEST List / quote I could find was this one by @boostin
On 28/06/2009 at 9:01 PM, Guest boostin said:
You will need -
Gearbox
Rear diff (only if the auto and manual have different diff ratios)
Prop shaft (auto shaft is shorter than a manual)
Gear stick and linkages
Pedal box
Clutch master, slave and line
ECU, not sure on this one. On mine I snipped 1 wire. Earthed told the ECU it was auto, open circuit for manual.
Flywheel (with bolts)
Clutch assembly (with bolts)
Gearbox oil
Others will add if I missed anything.
All gearboxes will bolt up.
  • Thanks 1
  • Similar Content
    574.7k
