Centre Diff Swap
Rosssub
This is a merge of posts from my garage thread. Covering my BH5 GTB 5MT centre differential change to a Version 8 WRX centre diff:
http://www.clubsub.org.nz/forum/index.php?/topic/40292-rosssubs-gtb/&page=4
Started ripping the BH centre diff out this evening. After driving at 100kph for a while, then trying a tight turn it's locking up pretty bad. Car jerks forward violently as though all the CV's are stuffed. Also making it under steer easily at any speed when the centre diff's hot/binding.
Jacked up and GB oil drained:
Driveshaft out:
GB supported with a jack:
GB cross member removed
Here's the shifter linkages at the rear of the GB:
Shifter linkage and stabiliser unbolted:
Locking slide pins removed from shifter linkage knucle:
After removing both locking pins (inner/outer) the shifter linkage knuckle will come off:
Exhaust hanger bracket and transfer case rear cover unbolted:
Rear cover (extension case) ready to come off:
Using a flat head screwdriver and hammer to separate the transfer case/rear cover:
Worked apart nice and evenly:
Centre diff and driven gear coming out:
Removed:
Driven gear shaft and centre diff slid out of rear cover:
Transfer drive gear removed from centre diff:
Gasket surfaces all cleaned up and ready for the replacement diff to arrive:
Here's the replacement centre diff, it's from a Version 8 WRX.
BH5B (TZ254) - Version 8 WRX (DA230)
BH5 - V7 WRX
New diff installed into rear casing then lubricated:
3-4mm bead of gasket silicone on the transfer case:
New center diff/rear casing installed and torqued to 40 Nm(29.7 ft-lb), then exhaust hanger bracket back on:
Shifter linkage knuckle and stay back on:
GB crossmember and driveshaft back in:
Just topping the oil up (3.5L), then it's time to set the new EBC up. :)
Here's a thread by Gazzy2000 covering swapping to an earlier phase 1 WRX/STI centre diff, centre casing and rear casing:
http://www.clubsub.org.nz/forum/index.php?/topic/14690-center-diff-gone-in-your-bh-heres-a-very-cheap-option/
Then DRFVDR's centre diff locking for RWD how to thread:
http://www.clubsub.org.nz/forum/index.php?/topic/20114-centre-diff-locking-for-rwd-how-to-by-uncle-darth/
