Broken mudguard/skirt screws
willisnz
I'm replacing the mud-guards and skirts on my BH Legacy, when I go to unscrew the screws that hold them in place they just keep turning and turning but aren't actually unscrewing....
I did get one off, so I know the screw goes into a clip, which I'm assuming is broken so the "nut" on the other side just turns when I turn the screw.
Anyone dealt with the before? At this rate I think I will just grind the head off the screws so I can get the mud guards off without destroying them or just ripping the screw out.
On 10/28/2016 at 5:53 PM, pedro said:
Are you supposed to be able to get them out without rooting them or are they a one time thing ?
Yeah, in theory I should just be able to get them off with no damage. I only really care about not damaging them in case I have issues putting the Rev-D skirts I got onto my Rev-A car and therefore need to revert back to the original parts.
On 10/28/2016 at 8:30 PM, loner said:
Try unscrewing it with another flat head screwdriver wedged behind... often those screws can't get going themselves but will with some encouragement.
That was my initial method, will try it with a bigger flat head and being a bit more aggressive and if that doesn't work straight away then I'll get the saw out:)
