Rotor Skimming/replacement
My knowledge on braking stuff and when something is stuffed is pretty damn limited so figured I better ask the internet experts at Clubsub for a quick opinion.
Been having a bit of squeak when first applying the brakes when cold (no squeak once used a couple of times) for a while which has now turned into a minor shudder when braking and a faint skimming sound when driving close enough to something for the noise to bounce back. Figured it'd be time to get the rotors skimmed. Not much of a lip on them so shouldn't be a thickness issue.
What do others do with the pads in this situation? All four corners have heaps of meat left on the pads so would rather not replace them unless I really have too. Would a re-bed in be enough? Is lightly skimming pads a thing?
Seems to have some weird contact issues on one of the front and one rear. Wondering if the rear one just needs some form of lube on the slide pin to get the top of the pad pushed in again as it may just be jamming at the top so only pushing the bottom half against the rotor. Think there may be something in the front pad as its a single very thin groove. Mainly interested in peoples opinions on whether to reuse old pads or not as I can't seem to find any other info on this exact situation
Front Passenger side
8177FFD3-6C2E-4201-857B-EA734A1935E1_zps
Front Driver side
80264265-42BA-49A3-A740-E3C0C678971D_zps
Rear Passenger side
BDEDB536-B85E-4D59-8DDF-C604C8E4987C_zps
Rear Driver side
008E1479-C3CF-40FD-AF28-6AC40773D8F3_zps
40C47D8D-427E-49B7-AE5A-C5E869263785_zps
