Surface Rust on WRX STI Transmission
eZ_Harry
  • 3 weeks later...
On 1/22/2017 at 6:11 PM, eZ_Harry said:
Hello,
This is a photo taken from a 2002 V7 WRX STI I was just looking at, noticed this bit of surface rust around the transmission and wanted to check if this was anything to be concerned about?
Short answer... It's all gravey. If you're concerned about it, take the box out sand back the areas with surface rust, and repaint. nearly the entire gearbox is casing is alloy aside from that plate which is steel.
