Front left brake binding / not releasing.
Hey team,
Have been having some trouble with my front left brake of late.
I took the B4 into mag n turbo about a 2 ish months ago to get a free brake check due to the fact I was to lazy to do it my self.
After having it checked I noticed a knocking in the front left tire when braking.
About another week later I started to have problems with the brake binding.
The brake is staying on for some reason that I'm unsure of, I've pulled the calipers, pads everything apart and everything seems normal and moving freely.
After pulling the brakes apart it seemed fine for about a month until yesterday.
The car will pull to the left and you can feel the bind coming through the steering.
It's auto so normally it will sit at 50-60kmh in the 1:1 ratio and sit around 1500rpm with no problems.
With the brake playing up like this it struggles to keep at that rpm and normally has to constantly change down to keep at that constant speed.
Have tried disconnecting the ABS system and had no change.
Fairly stumped for ideas, Anyone got any ?
Thought it might be a fluid return line causing a slow release but its highly intermittent. ???
 nickmcgill said:
Hey team,
you've described a problem I had a few months ago.......swap the caliper out. Rebuilding/recon too expensive
Yeah sounds like a piston prob to me, I just rebuilt a pair of two pots. Buying a secondhand caliper will be cheaper, but you'll learn a lot more if you rebuild it, though the seals and boots alone for them are about $60 new, let alone the pots, and you could get two new front calipers for about $60 if you shop around. I think its a fairly common occurrence that they rust out cause the seals wear down, water gets in, and it doesn't help how corrosive brake fluid is ;D
Okay. I'm now looking for a second hand calliper for that brake.
2000 B4.
If anyone has one in the chch area please PM me need to get it on asap as this one won't even release now.
I'm also a poor student with no income so I can't afford to get new one sadly. :'( :'(
