EJ20X Idle Control
Legacy
Hey guys,
I am wondering if there is an idle control valve on an EJ20X like on the older model EJs (like my EJ20R). If not, is there a way to raise the idle slightly to avoid a vibration at low revs.
The EJ20X in question does have an electronic throttle body and 5-speed auto if that helps at all.
Thanks in advance
Thanks guys,
I am going to try a throttle relearn first. I am also going to look into getting a VAGCOM and downloading a FreeSSM just so I can see what is happening.
Any suggestions on VAGCOM or FreeSSM to use?
Throttle Relearn Procedure (Courtesy of ADIKT from another thread)
http://www.uklegacy.com/forums/index.php/topic/128159-how-to-idle-re-learn-after-battery-disconnect/
Edited by Legacy
  • Similar Content
