RA Roof vent on V7 Wagon
Subru
You have map lights, yes? Assuming you do those will have to be removed. Then there is a bracket the lights bolt too which is spot welded to the roof vent bracket underneath (GC/GF all have thato bracket stock), assuming the 7 wagon does as well. That will need to be carefully drilled off the roof to break the spot welds, you will then be able to bolt everything in easily, assuming you have all the parts.
You will have to drop the roof lining down in order to see if the bracket is actually under the map lights and obviously cutting and drilling holes in the roof for mounting etc
Pretty sure I have map lights.
When everything arrives (hopefully this week) ill drop the roof lining to see whats going on. I hope all the bolts and things come with it. Its second hand and ill give everything a repaint just to freshen it up. Also get the main part painted blue (currently white) professionally. Shouldn't cost too much for that.
@4G63B8 Yeah, I tried to find another Wagon with it but couldnt find much. In the US I dont think they have Sti Wagons so they stick with Sedans.
@Batbaruman Any tips?
Tempted to do a write up or video on installing it on the wagon if I have time.
Finished installing roof vent but still need to paint blue.
Other than being second hand and a bit old it works very well at pulling air in as my cars air conditioning goes down to 20 degrees and does nothing to cool the car down when its 30 degrees outside. This works very well with low noise, very happy with that. Also looks mint :P
Here are some pics and yes it hurt cutting holes in it... :(
  • Like 5
42 minutes ago, Inked said:
awesome! can I buy a kit anywhere or do you have to grab them when they pop up on trademe etc.
I was very lucky and got it off trademe for $100, snapped it up shortly after it was listed. You can buy a new kit from japan but costs 700ish total. Its the only V7 one I have seen on trademe since the 5 months I have been watching new listings. They do pop up on FB but still not often.
Just now, willisnz said:
Are you sure you don't just need your A/C re-filled?
idk maybe. When its on 20 degrees (lowest temperature) and on full fan it does nothing in terms of making it colder, sounds like a 747 taking off tho.
9 minutes ago, boon said:
$100 is a steal, I had a GC8 one that sold in about 3 minutes for $400.
Yeah definitely, pretty hard to get.
Painted it myself just tonight, primer, base coat and clear. Gonna remove the orange peel tomorrow and it will look new :P
Came out minter than I expected :)
sorry bro missed the tag, only recently got back from 3 weeks away in Bali :D to be honest i'd have had no advice/tips anyway since Ajay at @Subirex Automotive did my install and I sourced my billet latch for it from @Dairusire
Looks like you done an awesome job on the install though. don't you love how efficient/effective these are? make minimal noise as well and as long as the car is moving it's an amazing supply of cool air. i still suffer in traffic though with no a/c :(
