Focus RS Limited
G BNGA
That puts it some 8 - 10k more than an STi doesn't it?
The RS was on my potential shopping when buying a new car but too many potential issues and felt STi was a safer bet. Still feel it was the right decision....
Gary
Yeah Even as this forums Euro hot hatch guy I'm not the biggest fan of the new RS, don't like the noise especially compared to the 5 cylinder noise of the old ST225/RS mk2 also I agree with some of the guys, it looks a bit bland.  But don't be so quick to write it off having been in one I'll take its interior and comfort over the new STi anyday
  • 4 weeks later...
Seems the head gasket failure is down fo a massive cock up at Ford.
The Ecoboost motor is also used in the Mustang but there are differences in its design. When assembling the RS motor, the head gasket used in a lot of cases was actually for the Mustang. This meant that water channels inside the head were compromised which lead to overheating and gasket failure. The assembly line obviously wasn't aware of the difference between the gaskets. D'oh!
The issue is also affecting models here in NZ. I know of at least one car that has had the engine repaired under warranty. Certainly glad I went with an STi....
On 02/02/2018 at 4:08 PM, newsuba said:
lol
the current focus rs is about to undergo a recall for duff head gaskets.
a problem they had with the first sierra cosworths back in the 80s.
seriously, an old subaru is like a tractor compared to the latest hot hatches.
And the 2.5 Duratec V6 - They had a really bad design on the back bank where there was bugger all gasket and these engines were well know to blow head gaskets externally. Mine had started to go when the gear box died, it would make a ticking sound as it leaked compression.
Also Ive seen a few videos on cracking blocks on the ecotec engines as well
I haven't heard anything about it been cause they used the wrong one. That's actually the big one that gets confused, yes they both 2.3L but they actually different engines. The RS engine is a reworks Focus ST (2.0) engine and not the mustang 2.3 one.
The issue comes from it been a Open deck designed engine which is great at 2.0L with low boost, but to make it a RS it becomes a horrible idea.
Also thing to remember for stock RS's it's actually very very few affected, but for anyone who even does flash tuning software and up's the boost the nightmares begin.
Really sad as when its running its a damn great car.
I saw something on the MRT youtube videos, where they talk about the intercooler. ApparentlyThere's a cover that's stuck on the front to reduce the amount of cooling it receives. It was put on due to cars in warm moist climates condensing water in the intercooler. But you should be able to remove it to increase cooling.
Edited by SpeedySub
Happened to watch the MCM episodes on the RS last night and when going through the factory it was mentioned that it was the 2.3 mustang ecoboost block with different heads and cylinder liners, pistons etc. Wouldn’t be surprised if they were mistaken though
@SpeedySub Also over efficiency in super cold area’s was mentioned as a reason too
there is only one basic ecoboost 2.3, based on the older ecoboost 2.0, albeit in different states of tune for explorer, mustang, focus.
forgot about the duratec 2.5, a that was a sweet little v6, the best part of the old radisich telstar
