Howdy folks, i need to repaint the whole piece of trim on the rear hatch of '08 gtb facelift. The piece that houses the reverse and fog lights, badge etc but cannot figure out what im missing, have the interior of the hatch off and found the obvious two 10mm nuts to remove but otherwise i see nothing. Any help would be greatly appreciated!
If I remember correctly from when I removed mine over 3 years ago, there are more like 6-8 nuts which need to come off to allow the garnish to be removed... All symmetrical of course (either side of the badge), the final on is located very close to the outer edge of the garnish and is what caught me up for a while because it isn't easily visible.
What ever you do, do not pull on the plastic if it doesn't want to move otherwise you will crack the garnish, you likely still have a nut to remove and it will easily pull away from the hatch once they've all been taken care of. Good luck dude.
On mine, it was obvious, but I missed the bolt that is behind the badge on the back , I though maybe that just slid on to a stud.. but no theres a bolt.  I never managed to get the hand pull bit off the right hand side so I could fully remove the plastic but it was enough to install my reversing camera where the number plate light is
  • Similar Content
