Screeching wheel noise
Is a rock stuck somehwere or has something failed? Driver's side front wheel.
Wife thinks it started while she was driving around.
Jacked it up and tried to wobble the wheel and it seems fine. Anything else I should check? Pull the calliper off?
Eww...
Worth getting the caliper off to narrow it down to braking or something further in. Can you shake he caliper at all? Had a caliper bolt work it’s way out on an old car which let it flex just enough to always rub on the rotor. Didn’t sound quite that screechy though.
That sounds like a stone or something is caught somewhere between the caliper/rotor and backing plate.
Sadly, to make it easiest, the wheel will have to come off.
And be great full you're only dealing with STEEL calipers. Not alloy Brembos etc. Low chance of stripping threads
Edited by Individualities
