Ok fill in a blank for me here, seems not that rapid for a built motor and Gt3582? Kent from Speedsource went 10.9 with the stock turbo in a GDB?
Edit: ok it seems Subarus need heaps of beans to go down the strip in a fast time, good stuff. Speedsource must have been doing some magic sh!t...
What Kent did around ten years ago was pretty cool, 10sec 1/4 with a stockish turbo and plenty of nos is no easy feat. It’s also not everyday a Subaru runs a 10sec quarter or even an 11 with the amount of supposed 300+kw Subaru’s out there these days. There would be less than ten Subaru’s in nz to have gone 10sec or faster. We are pretty proud of what the car has achieved so far and look forward to going quicker.
Cheers Matt.
  • Like 6
Probably coz we don't care about drag racing :P
Good on ya though.
What front and center diffs are you running? How much power?
Mates 400kw GD has been running fairly contestant 11.6's but traction is letting him down 1st/2nd (average tires admittedly)
Didn’t @Pappu1 run an 11 in a reflashed V7? Or I may be wrong. 10sec is awesome though dude that’s a big achievement! Anything 11 sec bracket and under is a bloody quick car !!
2 hours ago, Niran said:
Bloody awesome @SIRREX !
I managed 12.6 @250kw in the heavy GVB sedan complete with Sub lol
Hoping to get low 11s with the new 350kw setup.
You making it down on Friday?
that was a while ago. stock vf30 and top mount with exhaust and aggressive reflash..
LOLGTR had a 10 comming from all the hard work put into it and great to see Matt planning to push it more
Go the suby!!!!!
well done boys
@pl0xIts currently running a bl bp 6 speed with v7 sti front lsd, stock centre diff and grb r180 rear diff. We run hoosier drag radials and just need more time to dial in the car to drop the 60fts. @Niran You should see 11's with ease, we were previously running 11.4 with a 7670 till the turbine wheel decided to give up.
19 hours ago, Niran said:
@itsmitchlowe guessing no speed sensor? Thinking it might be wise for me to get one then
I reckon you might be overthinking things just a little ;)
Nice. Good to see more an more quick subis out there mind you last nightwars I seen about 3 doing low 11z which is good to see
Sent from my SM-G950F using Tapatalk
@StrokedEJ definitely great to see some more subis out. I know the black wagon runs NOS. The Autech GDB is on a stock-motor which is almost unbelievable, trapping 133mph. Will see what some more tuning and the switch to E85 brings us - hopefully some low low 10s and/or high 9s
