New Turbine Speed 2 sensors available on Trademe.
The later version of 5EAT transmissions are notorious for P1710 faults. Subaru’s fix is a new valve body $4200+++
The Hall effect shaft input sensor is the problem. Replace it yourself an easy fix.
Edited by Tony64peter
  • 4 months later...
On 21/04/2019 at 1:19 PM, GDR260 said:
Having same problem with mine , whats the part called? Thanks
What's your vin number on the plate on the drivers side strut tower? Should be fairly easy to track one down on partsouq.com using that number.
  • 2 months later...
Has anyone found a good source for the turbine 2 speed sensor problem yet, I tried a universal, but it is too long.  Looking for a good part number I can get in the US
  • 2 months later...
I get a hard shift in to 3rd all the time.... got told it was unable to be fixed by having a subaru dealer upload new transmission software patch
Never had a fault code show though....
How easy is it to swap the sensor?
    574.7k
