Split CV Boot: Advice please!
tigerstyle
Just looking under the bonnet prepping for a timing belt change, and saw a lot of dark grease on the drivers side... :(
https://imgur.com/a/JrUZWSG
So boot is split, must have only been like that for a few days so have caught it early and no noise yet.
So best option? Dealer say $70 for the boot kit, Repco says have axles for $240-260
Think just changing the boot will be ok, but looking for advice on what would be the normal 'go to' fox for you guys?
This guy makes it look easy, I don't have an impact though, so is standing on the brakes enough to undo the hub nut using a large breaker bar?
https://legacygt.com/forums/showthread.php/replace-rebuild-torn-cv-boot-and-axle-108975.html
This guy makes it look even easier!
Bit of debate on if taking the ball joint out is easy or not, my car isn't rusty, so think it should be ok, that or move the whole strut around.
Cheers! All this right before the holidays too...
Edited by tigerstyle
Repco won't sell you axles, just CV kits as far as I know. $70 is a S*** tonne of money for a rubber boot,
grease and a couple of cable ties.
If I have a ripped boot, I generally remove the whole axle, remove both CVs, clean completely, inspect and repack
with grease and new boots. You only need to replace the CV if it's worn.
The axle nut on the hub can be anywhere from hard to get off to impossible... the last one I did
had to be cut off with a hammer and chisel. Most of the time they will come off with a large
breaker bar... a long extension pipe might be needed. The hand brake should hold the car still.
If the inner CV boot or CV is the one that needs replacing, you could just change it while on the car... won't be
that hard.
Edited by Loren
that hard.
 Got it from the dealer for $60 in the end, don't think that is too much more that Repco/Supercheap factoring in it is a genuine part with all the extra clips and circlip required etc. Need to get going with BNT and the likes of those guys, but considering  I picked it up from Subaru Saturday morning and it is already fitted by myself (working around this weather!) I'm happy to have gotten it fixed quick.
Didn't want to keep driving on it and risk longer term damage being done.
And yeah, was just the inner so followed the vid, and no need to mess with axle nuts etc.
Everything genuine in NZ is super expensive...just a single axle nut is $25!
I thought the $70 was the repco price though... which would be ridiculous.
Well done getting it fixed.
  • 3 years later...
