5 speed e tune 2 (2002 bh5) Not sure of the code.
My gearbox rattles (clicking like worn bearings in a housing).
From research it could either be the center diff or the input shaft bearing. It rattles while in gear but decelerating and also while in neutral coasting - sounds like bearings in a housing spinning. It only happens when the car is moving and slows down as the car slows down.
It's not metallic and it's not anything to do with the wheels or brakes as far as I'm aware.
Keen to know what your thoughts might be or whether should just replace the gearbox?
Sent from my SM-N950F using Tapatalk
1 hour ago, Boxer4turbro said:
Hey hey,
Anyone keen to do a gearbox for me? My one is 5 speed e tune 2 (2002 bh5) Not sure of the code.
Mine rattles like crazy, probably the center diff. It rattles while under load, while in neutral coasting etc.
I don't have a gearbox so I'm hoping the community might have access to one.
I appreciate any comments or thoughts.
Have you checked the gearbox transmission mount? Sometimes the rubber breaks off the metal casing and lets the the tranny move around a lot more. Also just a side note, if you have a upgraded pitch stop mount you will get a lot of extra noise and vibration / feedback from the transmission. Other than that people have had success with changing the fluid. If all of the above has already been checked, good luck with the tranny repair
Cusco? 100% take it off and gearbox vibration will most likely stop. I bought one and took it off two weeks later because it sounded like rod knock in 1st 2nd and 3rd gear. Shifts great but I hated the sound / vibration. It basically allows the engine and gearbox frequency to resonate through the firewall because it’s 99% metal  with no dampening (aka rubber bushes)
I'm not entirely sure how to upload audio but I've created a link.
https://s.amsu.ng/HHZnAaSDBzQN
Please have a listen and see what you guys think.
The clicking is very central. Gearbox area but behind the dash. So this is when it's in neutral coasting or in gear decelerating, also happens coasting in reverse.
The gearbox doesn't crunch at all and shifts perfectly fine.
    574.7k
